Remotes don't work with new Sky HD box
Gisbon
Posts 1
Gisbon Posted: Sun, Jun 7 2015 4:47 PM
i have a beo vision 7 that used to be connected to the sky box with what looks like an infrared connector. When I upgraded my box to an HD box this no longer works.  I can now only use the sky remote which is no good in other rooms.  Is this a simple device purchase or will I need an engineer.  Thanks
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Jun 7 2015 6:54 PM
You may check if your box as a Bluetooth / infrared setting.
You need infrared for the PUC.
w5bno123
London
Posts 578
Hi
What BeoVision 7 do you own?
If it's a MKIII 7/32 and If the sky box is connected to the TV with DVI/HDMI and scart you will need to enable scart control in the Sky box settings and set the PUC to Pace Sky +
malcolm welborn
canary islands
Posts 188
I have beo4 and beo 6 remotes beovision11 puc Thompson hd  version2
works no problem
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Mon, Jun 8 2015 9:11 PM
You haven't specified which Sky box you had originally: Sky Digital or Sky+. Neither of these remotes will work properly with Sky+HD. Also note that there are two versions of Sky+HD software available to be installed into the Set Top Box controller of your BeoVision 7.
You need to have a look at the list of boxes available in the set up menu of your set. If Sky+HD (usually listed as Thomson Sky HD) isn't there, you will need somebody to install a new list via the service tool. Not something you can do yourself unless you have access to the B&O service tool.
Opman
Aussie Michael
Melbourne, AU
Posts 3,730
you could try the foxtel digital cable puc as its the same box
Aussie Michael
Melbourne, AU
Posts 3,730
I looked on the Avant tonight and there are a lot of Sky PUC Codes, if you want me to take a photo of them let me know.
I am using Foxtel Digital Cable and the IQ2 (HD+) box that i originally had was using this PUC. This is the same as the Sky HD / HD+ going from the box and the remote
I recently upgraded to IQ3 which is a different box and a different remote and uses cable and IP. The foxtel remote is bluetooth.
There was an update to the Foxtel Digital Cable PUC and i have havent had any issues using the original PUC with the upgraded box from IQ2 to IQ3. The only issue i had was some lag and turning the box on with my buttons.
I since changed the IR strength to low and this has helped.
Regards
Michael.
Page 1 of 1 (7 items) | RSS
