Seems like Geoff has lifted of the lid on some tech concerning the BeoLab 5 successor
What is “Beam Width Control”?
http://www.tonmeister.ca/wordpress/2015/06/30/bo-tech-what-is-beam-width-control/
Active Room Compensation
http://www.tonmeister.ca/wordpress/2015/06/30/bo-tech-active-room-compensation/
Therefore the use of a tablet to measure the sweet spot and getting to this 360° Sound experience.
kuyttendaele:What is “Beam Width Control”?
BeoNut since '75
kuyttendaele: Seems like Geoff has lifted of the lid on some tech concerning the BeoLab 5 successor What is “Beam Width Control”?
Probably a much more sophisticated and DSP controlled precise version of the old Bessel array which is used a fair amount in PA and such systems. Using multiple drivers covering the same freq range a Bessel array can create a very narrow and controlled beam even with a large number of drivers, by wiring them in and out of phase in a pattern. Yamaha took this further, as noted, and did a fine job with it.
Jeff
