Next generation B&O speaker tech...
This post has 5 Replies | 2 Followers
kuyttendaele
Posts 707
kuyttendaele Posted: Tue, Jun 30 2015 3:17 PM
Seems like Geoff has lifted of the lid on some tech concerning the BeoLab 5 successor
What is “Beam Width Control”?
http://www.tonmeister.ca/wordpress/2015/06/30/bo-tech-what-is-beam-width-control/
Active Room Compensation
http://www.tonmeister.ca/wordpress/2015/06/30/bo-tech-active-room-compensation/
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Tue, Jun 30 2015 4:20 PM
Thanks Karel.
Frederic
Belgium
Posts 121
Frederic replied on Tue, Jun 30 2015 9:37 PM
Therefore the use of a tablet to measure the sweet spot and getting to this 360° Sound experience.
elephant
AU
Posts 8,219
kuyttendaele:
What ever it is ... be careful the beams don't cross
https://www.google.co.uk/search?q=don't+cross+the+streams&source=lnms&tbm=isch&sa=X&ei=F2yTVcrtDobGmAXvlIzYCg&ved=0CAYQ_AUoAQ&biw=320&bih=460&dpr=2#imgrc=qi-AZj3aauZ8dM%3A
BeoNut since '75
TWG
Posts 1,672
TWG replied on Wed, Jul 1 2015 6:36 AM
kuyttendaele:
Maybe it's somewhere identical to the IntelliBeam technology from Yamaha which they're using since a few years in their digital sound projector speakers - which sounds amazing by the way!
I've heard one of their 1st speakers with this technology a few years ago, the YSP-1000 and I had to ask twice during the presentation if there really wheren't any additional speakers connected. Big Smile
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jul 1 2015 2:48 PM
Probably a much more sophisticated and DSP controlled precise version of the old Bessel array which is used a fair amount in PA and such systems. Using multiple drivers covering the same freq range a Bessel array can create a very narrow and controlled beam even with a large number of drivers, by wiring them in and out of phase in a pattern. Yamaha took this further, as noted, and did a fine job with it.
Jeff
Page 1 of 1 (6 items) | RSS
