Please can anyone help me with a picture of where the belt go on a beocenter 2200, my belts had disintegrated, so am stuggling to fit the new ones.
Thanks Tim Jones
If no instructions were included, i suggest you ask the seller for some.
Thanks for taking the time Dillen, I didn't get any instructions apart from a page from the service manual which I find hard to follow. I've had a go and after some trial and error have come up with this which seems to work. What do you think? Thanks again
Tim
The belt path is correct in the photo.The capstan belt, I think, looks a bit on the thick and heavy side, but that may just be the photo.(It shouldn't be a too heavy belt, putting a too hard sideways load on the motor bearings).
Thanks Martin, the capstan belt is quite slack so hopefully Ok
