Beocenter cassette belts
TimJones51
Posts 3
TimJones51 Posted: Wed, Jul 1 2015 11:20 PM
Please can anyone help me with a picture of where the belt go on a beocenter 2200, my belts had disintegrated, so am stuggling to fit the new ones.
Thanks Tim Jones
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 3 2015 1:52 PM
If no instructions were included, i suggest you ask the seller for some.
TimJones51
Posts 3
Thanks for taking the time Dillen, I didn't get any instructions apart from a page from the service manual which I find hard to follow. I've had a go and after some trial and error have come up with this which seems to work. What do you think? Thanks again
Tim
Dillen
Posts 13,191
Dillen replied on Sun, Jul 5 2015 6:29 AM
The belt path is correct in the photo.
The capstan belt, I think, looks a bit on the thick and heavy side, but that may just be the photo.
(It shouldn't be a too heavy belt, putting a too hard sideways load on the motor bearings).
TimJones51
Posts 3
Thanks Martin, the capstan belt is quite slack so hopefully Ok
Tim
Page 1 of 1 (5 items) | RSS
