Beocenter 7700
This post has 3 Replies | 0 Followers
knastaksel
Posts 7
knastaksel Posted: Tue, Jul 21 2015 5:46 PM
Can I use Beolink 1000 as remute control for my Beocenter 7700,
Knastaksel
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 21 2015 6:18 PM
No.
You will have to use the newer version of the Beocenter Terminal (hand control) or, ideally, the
two-way  Master Control Panel MCP 7700.
knastaksel
Posts 7
Hi
Thanks for answar , you mean the the hand control with the display, Beolink 5000 remote ?
Kurt
Dillen
Posts 13,191
Dillen replied on Tue, Jul 21 2015 7:02 PM
No.  I meant what I wrote above.
The Beocenter Terminal (newer version with the flush buttons) or the MCP 7700.
You can see the MCP 7700 here:
http://www.beoworld.org/prod_details.asp?pid=701
Page 1 of 1 (4 items) | RSS
