Can I use Beolink 1000 as remute control for my Beocenter 7700,
Knastaksel
No.You will have to use the newer version of the Beocenter Terminal (hand control) or, ideally, thetwo-way Master Control Panel MCP 7700.
Hi
Thanks for answar , you mean the the hand control with the display, Beolink 5000 remote ?
Kurt
No. I meant what I wrote above.The Beocenter Terminal (newer version with the flush buttons) or the MCP 7700.You can see the MCP 7700 here:http://www.beoworld.org/prod_details.asp?pid=701
