Avant 55 want to operate Kodi from Puc
StUrrock
Posts 995
StUrrock Posted: Wed, Jun 10 2015 10:04 PM
Any ideas? have tried a jail broken ATV2 and the B&O controls it brilliantly, but Kodi (aka XBMC) just runs too slow on the JB ATV2.
Borrowed a MadKatz Mojo Android and Kodi worked brilliantly (upscaled to 4k) via the Puc
Are there any other stb options for Puc controlled Kodi?
Beroli
Germany
Posts 316
Beroli replied on Thu, Jun 11 2015 5:56 PM
Hi
Have a look on a FLIRC-USB Stick. If you plug it in the KODI-Device after you programmed it as a Apple-Receiver, you could use the Apple-PUC to control the whole KODI-Interface with your Beo-Remote.
Cheers
Beroli
StUrrock
Posts 995
StUrrock replied on Thu, Jun 11 2015 6:05 PM
thanks Beroli I'll give it a go and report back
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jul 30 2015 12:40 PM
Any news on this one?
Ralf
Beroli
Germany
Posts 316
Beroli replied on Thu, Jul 30 2015 7:27 PM
I can asure you, that the FLIRC stick is working.
- Just choose the AppleTV Remote  Puc on the Avant,
- tape the end IR/PUC-Cable directly on the FLIRC IR eye,
- connect the flirc to a USB port on your computer, programm with the FLIRC software the buttons up, down, left, right and back, save the file
- disconnect the FLIRC device from your computer
connect the new programmed FLiRC to your Kodi device
Now you can use your Beo4/BeoRemote to remote your Raspberry PI.... Or other devices. Never regreted to buy this little FLIRC
Cheers Beroli
StUrrock
Posts 995
StUrrock replied on Thu, Jul 30 2015 10:56 PM
Thanks Beroli Using the FLIRC to control Droid box very good!
Page 1 of 1 (6 items) | RSS
