Hi
Have a look on a FLIRC-USB Stick. If you plug it in the KODI-Device after you programmed it as a Apple-Receiver, you could use the Apple-PUC to control the whole KODI-Interface with your Beo-Remote.
Cheers
Beroli
Any news on this one?
Ralf
I can asure you, that the FLIRC stick is working.
- Just choose the AppleTV Remote Puc on the Avant,
- tape the end IR/PUC-Cable directly on the FLIRC IR eye,
- connect the flirc to a USB port on your computer, programm with the FLIRC software the buttons up, down, left, right and back, save the file
- disconnect the FLIRC device from your computer
connect the new programmed FLiRC to your Kodi device
Now you can use your Beo4/BeoRemote to remote your Raspberry PI.... Or other devices. Never regreted to buy this little FLIRC
Cheers Beroli
