Hello All
If you have a Moment connected to a Network Link TV and want to keep the picture on screen when playing music from the Moment:
Normal 0 false false false EN-GB X-NONE X-NONE
V1 and Moment
Switch on V1 and initiate music from Moment (JOIN)
Press Menu and select Source list. This should highlight the Music from the Moment.
Press RED to access the “set up” feature.
Select ADVANCED SETTINGS
Scroll down to PICTURE OFF and press right arrow.
Select from: TIMEOUT, ALWAYS or NEVER.
NEVER means the picture NEVER turns off.
Press GO to store.
BeoNut since '75
Opman: Hello All If you have a Moment connected to a Network Link TV and want to keep the picture on screen when playing music from the Moment: Normal 0 false false false EN-GB X-NONE X-NONE V1 and Moment Switch on V1 and initiate music from Moment (JOIN) Press Menu and select Source list. This should highlight the Music from the Moment. Press RED to access the “set up” feature. Select ADVANCED SETTINGS Scroll down to PICTURE OFF and press right arrow. Select from: TIMEOUT, ALWAYS or NEVER. NEVER means the picture NEVER turns off. Press GO to store.
Interesting subject, I wonder what is the difference on the V1 between the setting 'always' and if you do 'p.mute' on your list.
With 'p.mute' the curtain closes, is the screen in this case completely off or is it just a beauty detail to view. Are in both cases the screen completely off-powered, or is it just the lamp off-powered what seems to happen immediately if you use the setting 'always' in the menu.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
