Network Link Moment & TV
Opman
Wilmslow, Cheshire
Posts 443
Opman Posted: Sat, Aug 15 2015 5:10 PM
Hello All
If you have a Moment connected to a Network Link TV and want to keep the picture on screen when playing music from the Moment:
Normal 0 false false false EN-GB X-NONE X-NONE
V1 and  Moment
Switch on V1 and initiate music from Moment (JOIN)
Press Menu and select Source list. This should highlight the Music from the Moment.
Press RED to access the “set up” feature.
Select ADVANCED SETTINGS
Scroll down to PICTURE OFF and press right arrow.
Select from: TIMEOUT, ALWAYS or NEVER.
NEVER means the picture NEVER turns off.
Press GO to store.
elephant
AU
Posts 8,219
elephant replied on Sat, Aug 15 2015 11:08 PM
If this was the post that was moderates I have no idea about what the system thought was suspicious !!!
The large number of CAPS ? But I often do that too.
The strange string of characters ? But I have seen that before too.
Maybe Keith could inspect the log for false positives- negatives and tweak the rules ?
BeoNut since '75
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Aug 16 2015 8:59 AM
Opman:
Hello All
V1 and  Moment
Press GO to store.
Interesting subject, I wonder what is the difference on the V1 between the setting 'always' and if you do 'p.mute' on your list.
With 'p.mute' the curtain closes, is the screen in this case completely off or is it just a beauty detail to view. Are in both cases the screen completely off-powered, or is it just the lamp off-powered what seems to happen immediately if you use the setting 'always' in the menu.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Page 1 of 1 (3 items) | RSS
