BV 11 and projector
This post has 5 Replies | 0 Followers
liviu_o
Posts 157
liviu_o Posted: Sat, Oct 31 2015 7:53 AM
Hello all!
Does anyone have a setup which includes a bv 11 and a projector. I am interested in adding a projector to my (future) bv 11.
Thanks!
Dave Farr
France
Posts 2,283
The answer will probably be yes, but what do you want to know? Clarity with the question leads to a more informed answer. Is it a new or used BV11? Are you asking for advice on which projector to buy r something else?
Dave.
badgersurf
Posts 539
if you search the forum for matrix, there have been several threads. Think the options that were suggested were either a HDMI matrix or an oppo blue ray player
liviu_o
Posts 157
liviu_o replied on Sun, Nov 1 2015 9:39 PM
I don't think new or used does matter...as a matter of fact is a new bv 11.
I want to know if it is posible to conect a projector to a bv 11 same way it was osible to hhok it to a beosystem 3 or a 7-55.
badgersurf
Posts 539
The BV11 does not have an HDMI out, so you have to use a matrix or something thing a Oppo.
there are lots of post covering this
Millemissen
Flensborg, Denmark
Posts 14,680
It is not!
You must use a HDMI matrix for external sources - some of these can be puc controlled.
If you 'just' need, what you can get from a good BRP (Discs, Netflix, DLNA from NAS) concider the Oppo player.
Page 1 of 1 (6 items) | RSS
