Hello all!
Does anyone have a setup which includes a bv 11 and a projector. I am interested in adding a projector to my (future) bv 11.
Thanks!
if you search the forum for matrix, there have been several threads. Think the options that were suggested were either a HDMI matrix or an oppo blue ray player
I don't think new or used does matter...as a matter of fact is a new bv 11.
I want to know if it is posible to conect a projector to a bv 11 same way it was osible to hhok it to a beosystem 3 or a 7-55.
The BV11 does not have an HDMI out, so you have to use a matrix or something thing a Oppo.
there are lots of post covering this
It is not!
You must use a HDMI matrix for external sources - some of these can be puc controlled.
If you 'just' need, what you can get from a good BRP (Discs, Netflix, DLNA from NAS) concider the Oppo player.
