Not sure if anyone else has come across this before? they're exclusive to John Lewis still.
I've had the same cr4ppy £30 vacuum cleaner since my first flat and it was cheap and needed emptying all the time but it did do the job. Anyway, we really have needed something better for a while so I though in usual B&O way, "I'll get something expensive that also looks quite smart and does the job"
Anyway, it's a rechargeable cordless hoover that actually has some decent suction on it and it doesn't weight that much either. Should be getting delivered on Thursday but I thought I'd see if anyone else had come across it?
Not much idea about it.
yep we've had a G -Tech Air Ram for maybe over a year...
Pros - Light, powerful, good battery life, easy & quick to charge, works well on hard/carpet areas
Cons - The head is a little tall and does not get under all spaces, no wall to wall suction, dirt collection compartment rather small, noisy.
We use ours as a secondary hoover which is perfect in the kitchen and with kids as it can come out quickly for those messy moments.
I would recommend following their advice and cleaning the filters once a month, its an easy job to-do.
Quirk - You can upload data to see how many calories you have burnt !
Would I buy one again yes, would I recommend one yes....
