Jag har en Beogram1000 med SP14 Pickup. Ljudet från Pickup skapar resonansljud I tonarmen så jag får ett lågfrekvent ljud I högtalarna. Finns det någon som vet varför. Skivspelaren sitter i en radiogrammofon Beomaster RG 900
First of all, Welcome to beoworld!
I have used google translate to translate your question, are you sure its the beogram`s tone arm? The speakers inside the cabinet have paper surrounds that wear out.
Wouter
Thank you for the replay!
Yes I'm sure that it is the tone arm. When i knock on it so can I hear the sound in the speakers. I have also an beocord 2400 in the cabinets and it sound great. So it must be the something else.
Well, if I were you I'd first remove the sp 14 and try if the problem is still there. If it is, a cable inside the tone arm is probably damaged. The tone arm comes off fairly easy but I`ve never replaced any cables inside it.
Hope this helps.
BTW, we love to see a picture of your setup!
Wouter: Well, if I were you I'd first remove the sp 14 and try if the problem is still there. If it is, a cable inside the tone arm is probably damaged. The tone arm comes off fairly easy but I`ve never replaced any cables inside it. Hope this helps. BTW, we love to see a picture of your setup!
I changed cables on my BG 1202, no bigger problem.
Yes I try that and it stills there. So i Think its cable also. So maybe i have to replace that. But I wonder in the pickup its a element before the needle can something wrong happens with that
Heres The picture
Okej
Thank you I try that
