Beogram 1000
This post has 7 Replies | 2 Followers
Thomas Igelström
Sweden
Posts 15
Thomas Igelström Posted: Tue, Jan 13 2015 12:32 PM
Jag har en Beogram1000 med SP14 Pickup. Ljudet från Pickup skapar resonansljud I tonarmen så jag får ett lågfrekvent ljud I högtalarna. Finns det någon som vet varför. Skivspelaren sitter i en radiogrammofon Beomaster RG 900
Wouter
Netherlands
Posts 302
Wouter replied on Tue, Jan 13 2015 12:58 PM
First of all, Welcome to beoworld!
I have used google translate to translate your question, are you sure its the beogram`s tone arm? The speakers inside the cabinet have paper surrounds that wear out.
Wouter
Thomas Igelström
Sweden
Posts 15
Thank you for the replay!
Yes  I'm sure that it is the tone arm. When i knock on it so can I hear the sound in the speakers. I have also an beocord 2400 in the cabinets and it sound great. So it must be the something else.
Wouter
Netherlands
Posts 302
Wouter replied on Tue, Jan 13 2015 3:21 PM
Well, if I were you I'd first remove the sp 14 and try if the problem is still there. If it is, a cable inside the tone arm is probably damaged. The tone arm comes off fairly easy but I`ve never replaced any cables inside it.
Hope this helps.
BTW, we love to see a picture of your setup!
Wouter
Søren Mexico
Mexico City
Posts 6,411
Wouter:
Hope this helps.
I changed cables on my BG 1202, no bigger problem.
Thomas Igelström
Sweden
Posts 15
Yes I try that and it stills there. So i Think its cable also. So maybe i have to replace that. But I wonder in the pickup its a element before the needle can something wrong happens with that
Thomas Igelström
Sweden
Posts 15
Heres The picture
Thomas Igelström
Sweden
Posts 15
Okej
Thank you I try that
Page 1 of 1 (8 items) | RSS
