Ouverture masterlink issue
This post has 0 Replies | 0 Followers
Maurice
Posts 108
Maurice Posted: Fri, Jan 1 2016 9:38 PM
Hi all and happy new year while i think of it, my question is about a issue i have with my setup. I have a ouverture that is connected to a MK 2 BV8/40  A-OPT 0 and V-OPT 2 as i am ONLY using the TV speakers no others.  i recently aquired a system module  51 pcb from ebay and installed it as per the instructions except for the last part of flash software update as i have no access to that . When  i press DTV everything works as it should then  if i press CD, RADIO, etc they all work on the  overture however, if i try to switch on the ouverture  before the TV is on from the remote with CD etc i only hear a click  but no sign of life from the ouverture. Any advice is it my installation or is it a software issue ?
Page 1 of 1 (1 items) | RSS
