Hi all and happy new year while i think of it, my question is about a issue i have with my setup. I have a ouverture that is connected to a MK 2 BV8/40 A-OPT 0 and V-OPT 2 as i am ONLY using the TV speakers no others. i recently aquired a system module 51 pcb from ebay and installed it as per the instructions except for the last part of flash software update as i have no access to that . When i press DTV everything works as it should then if i press CD, RADIO, etc they all work on the overture however, if i try to switch on the ouverture before the TV is on from the remote with CD etc i only hear a click but no sign of life from the ouverture. Any advice is it my installation or is it a software issue ?
