BeoSound Moment in 2021
mtlhd
Sweden
Posts 9
mtlhd Posted: Thu, Mar 25 2021 12:44 PM
Hi!
Having read all I could find on BeoSound Moment, picked one up second hand a while back. It was a bit tricky to get it up and running with drained batteries in the Jukebox but after leaving it charging overnight followed by a few factory resets it is now up and running. I have still not configured DLNA since my media server is not yet setup in our new apartment. Internet radio works nicely and streaming Deezer controlled from the B&O iOS app works great.
However, browsing Deezer on the Jukebox touch screen is not working. I keep getting an SSL exception associated TLS I believe - perhaps Deezer is no longer supporting TLS 1.0? I'm on software version 2.0.66.3399-2.2.22636.26265250 and even though the Moment says that there is a newer version available it repeatedly fails to update its software.
Any hope on resolving the SSL exception?
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Thu, Mar 25 2021 9:03 PM
Ah, the Deezer SSL issue is something that I've missed out totally, haven't used Deezer for a while on the Moment but will try tomorrow. Suggestion anyway is to open a ticket B&O Support since this would be easy fix for them to push out and should. Just that they let the certificates lapse is bad enough...
mtlhd
Sweden
Posts 9
mtlhd replied on Thu, Apr 1 2021 2:33 PM
I contacted B&O support, my issue has now been escalated to B&O HQ.
mtlhd
Sweden
Posts 9
mtlhd replied on Thu, Apr 1 2021 2:38 PM
I’m also curious on version numbering since it fails updating when trying both automatic and manual update of software. Jukebox is on 2.0.66.3399 and SoundHeart on 2.2.22636, is there a mismatch in SW versions 2.0.xx vs 2.2.xx?
Erik-nl
Posts 41
Erik-nl replied on Sat, Jul 17 2021 10:24 PM
Has your issue been solved?
mtlhd
Sweden
Posts 9
mtlhd replied on Tue, Aug 24 2021 12:33 PM
Not yet, I had some other things to tend to but I just sent an email to a local B&O repair center.
Page 1 of 1 (6 items) | RSS
