Comparison between Beovision 4-50 FullHD and Pioneer Kuro 6090 FullHD with BS3
Newbie
Posts 248
Newbie Posted: Wed, Mar 16 2016 4:40 PM
I own both of this two televisions.
Now the 4-50 is in our living room and it is getting to small.
I tried to hook up the Pioneer Kuro to the Beosystem 3 because the black is much better from the Kuro.
I watched the same film with both of them and now there is a problem.
With the Beosystem 3, the Kuro has an really dark picture. It is like a to heavily tinted sunglasses and the colors aren´t so crisp like on the Beovision.
I tried to change the settings at the Kuro but had not really success.
In the Beosystem 3 there are many settings.
Wich of them should I change?
I do not want to get in trouble.....
Does anybody know what to do?
Hope somebody can help me.
kind regards, newbie
Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
frog
Camberley UK
Posts 624
frog replied on Thu, Mar 17 2016 7:43 PM
You can access the beosystem 3 settings by both menu,0,0,Go or menu (move to options),red,go.
first thing you probably need to do is change the monitor auto detect to off and set your screen resolution. After that you can try some of the settings. Note there is a reset option if you screw things up too much.
Newbie
Posts 248
Newbie replied on Fri, Mar 18 2016 8:13 PM
Thanks a lot :-)
I have already switched of the "monitor auto detection".
The only problem is that the picture is not so crisp as on the Beovison 4-50.
It is like you would look through sunglasses and I don't know wich settings I should take....
Page 1 of 1 (3 items) | RSS
