Hi
I can't seem to use the app to switch my beovision on? Apparently wlan wake must be on but I can't find that option?
Ben
I don't know if this is the right answer or not. I do not use the Beoremote app but did try it out with my V1 many months ago. If I remember correctly, one of the things i did that may allow the app to start it, is under setup, then power saving, then standby, then quick start timers...setting timers for the times I might want to use the app.
Thanks Razlaw, the wake up Wlan settings were under the settings you mentioned. App turns the TV on now :)
