Beoremote app
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Tue, Mar 22 2016 5:52 PM
Hi
I can't seem to use the app to switch my beovision on? Apparently wlan wake must be on but I can't find that option?
Ben
Razlaw
Posts 4,345
Razlaw replied on Tue, Mar 22 2016 8:53 PM
I don't know if this is the right answer or not. I do not use the Beoremote app but did try it out with my V1 many months ago. If I remember correctly, one of the things i did that may allow the app to start it, is under setup, then power saving, then standby, then quick start timers...setting timers for the times I might want to use the app.
BenSA
Posts 1,404
BenSA replied on Wed, Mar 23 2016 6:43 AM
Thanks Razlaw, the wake up Wlan settings were under the settings you mentioned. App turns the TV on now :)
Page 1 of 1 (3 items) | RSS
