Powerlink RJ45
This post has 8 Replies | 3 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Mar 30 2016 9:03 AM
Are the powerlink RJ45 cables wired as normal Internet/LAN cables?
In other words, can you use a regular cable to connect speakers to an Essence, or do you need to buy a specific cable just for this?
leosgonewild
Helsinki, Finland
Posts 2,373
What I am askin is can you use acat6 or cat7 cable?
Millemissen
Flensborg, Denmark
Posts 14,680
http://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=1&TPN=14
Scroll down a bit.
Chris Hassell
London
Posts 396
leosgonewild:
I have speakers connected to my essence across the other side of the room (so using cat7 I had installed to go to my cellar) - so yeah is the answer! I had a cat 6 cable from the essence to the wall socket at one point but it created noise in the speakers.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
leosgonewild
Helsinki, Finland
Posts 2,373
Ok. I sold my Essence with a regular LAN-cable, so I guess it was the wrong one. Had to order one from soundsheavenly and have it shipped to him Surprise
ErikVonAgnar
Posts 193
Hi Leo!
I used to have normal LAN-cable Cat7. My Beo dealer said that Cat7 was needed.
//EA
Beo in white is my thingBig Smile
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
Millemissen
Flensborg, Denmark
Posts 14,680
I guess this is about (better) shielding!
rob08
Posts 209
rob08 replied on Wed, Mar 30 2016 6:54 PM
leosgonewild:
I'm pretty sure cat6 will work as long as it is shielded.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Mar 30 2016 8:46 PM
rob08:
Shielded cable & plugs are definitely required as the shielding carries the data ground. Technically even shielded cat 5 would 'work', but...
...cat 7 patch cables tend to be of the S/FTP type, which means that as well as having an overall shield, they also have an individual foil shield covering each of the twisted pairs within the cable. The overall shield provides shielding from interference from outside of the cable, whilst the additional shield around each twisted pair provides shielding against interference from the signals in the other pairs within the cable. If using cat 5 or cat 6 cable without this additional shielding there is the potential for hum to be introduced to the audio signals from the signal & data signals being carried on the other pairs which is why cat 7 is recommended.
Martin.
Page 1 of 1 (9 items) | RSS
