Hi Martin, I know this was in 2012. However, can you connect a beolab 5 with beovision 11 directly with a powerlink? do they both have a powerlink 8 pins port?
No problems there - just use the right RJ45/PL to DIN/PL adapter/cable.
Your dealer or Steve from Sounds Heavenly can provide this.
B&O use the BL90'es with the Avant - so why not not use the BL5's?
Should have written: 'so why not use the BL5's with a BV11?'
