BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
You can use one of the MySettings button as permanent light button?
L1NO:You can use one of the MySettings button as permanent light button?
@Chris
You are pointing at the single most annoying issue with the newer remotes, I refer to it as the "I forget what I am doing!" syndrome!
There is one solution, but at first you will properly reject it, as being far out.
The BL1000 does NOT have this issue, and despite being 30 years old it uses exactly the same protocol and carries the same commands as the newer ones. Virtually all commands are available directly, without digging deep into menus, and it knows exactly what its doing!
For my Cinema setup I am actually using the BL1000 exclusively, since it can be operated in the dark
Menus? Good in restaraunts but not on a remote. I have considered changing one of our Beo4s for a RemoteOne but the light button has gone....
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
There it is the link says it all
"Like the light, how this guides the ship to land
I found it when you touched my hand"
You may have noticed that the LAMP button, available in the list under LIGHT doesn't work properly with the current firmware. It doesn' t look like they are going to fix it.
This has prevented me from buying more Beoremote One.
Beoworld app with direct photo upload and emoticons.
BEOVOX141: Virtually all commands are available directly, without digging deep into menus, !
A bit like going into a restaurant without a being able to read the menu...
...you simply have to remember it from the last time, you were there.
Some can, most of us can't ;-(
P.S. What is the command for 'Join' (or MOTS......) on a BeoLink1000?
How am I to know, which device is activated by e.g. 'V.Aux2'?
@MM
The join command is merely the old CD2 (0x97) command rebadged,- SHIFT CD
Glad to be of assistance
Talk about longevity, - 30 years ago the B&O engineers designed a system capable of operating devices, not even invented yet!
Oh yes - 'SHIFT CD' --- the SHIFT button surely is a mighty one.
(Some of us have known that for decades).
The BeoLink1000 is the remote for the BeoNerds - everyone else need some help from a e.g. BeoRemoteOne.
At least if they have a setup, where several different commands/functions are needed.
Just imagening that my wife would have learn the SHIFT functions by heart ;-(
P.S. Even I would have a problem learning these and looking up these combinations on a piece of paper (or on my iPad!) when I have to use them, can't be THE solution.
Might work well for you, though - be happy ;-)
Anyway 'your solution' doesn't answer the question, that Chris asked!
What is the reason, that you want to keep the LIGHT mode constant?
Thanks Chris - that makes perfectly sense.
Now I see 'your problem'.
Hoping for a change in the settings of the Essence ('TV' command passthrough) probably would be more realistic than hoping for changes in the BROne.
