Turn on tv with MCP?
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Fri, Sep 11 2015 7:41 AM
I always assumed that it is not possible, but if you don't ask, you will never know.
Is there any way to turn on TV or DTV/SAT on a Beovision by using a Master Control Panel 5500/6500?
The button is not present, but is there any key combo that will send the right command?
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Sep 11 2015 8:08 AM
No, the MCP cannot send any video mode commands. Programming the TV in option 2 and pressing AUX won't work either (I just tried).
edit: you can turn it off that way, though! Odd.
--mika
leosgonewild
Helsinki, Finland
Posts 2,373
Too bad Sad Would have been awesome as a table remote with my system.
leosgonewild
Helsinki, Finland
Posts 2,373
Too expensive.. Sad
Stefan E
Sweden
Posts 101
Stefan E replied on Mon, Jun 27 2016 2:01 PM
A late reply to this topic.
Not shore if this work it or if it just activate the TV with a picture mute function for distribution of Audio?
Try to press Aux followed by a digit 1-9 can´t remember what Video unit that was for what but this way I could control and switch video sources directly on the Becenter 9500 itself, I assume the same logic still exist.
-Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
BenSA
Durban, South Africa
Posts 1,404
BenSA replied on Mon, Jun 27 2016 3:12 PM
It would have been amazing if the MCP could do this, such a pity it wasn't thought of. I'd definitely dust mine off and use it.
Page 1 of 1 (6 items) | RSS
