No, the MCP cannot send any video mode commands. Programming the TV in option 2 and pressing AUX won't work either (I just tried).
edit: you can turn it off that way, though! Odd.
--mika
A late reply to this topic.
Not shore if this work it or if it just activate the TV with a picture mute function for distribution of Audio?Try to press Aux followed by a digit 1-9 can´t remember what Video unit that was for what but this way I could control and switch video sources directly on the Becenter 9500 itself, I assume the same logic still exist.
-Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
It would have been amazing if the MCP could do this, such a pity it wasn't thought of. I'd definitely dust mine off and use it.
