Hello,
I have a bV10-32 and I want connection my 2 beolab 14 sattelite with powerlink .....===>.
I connect a powerlinkcable between the BV 10 and the ampli. Type 1741 and I connect the speakers with the passive cable with the PLP2 ampli. The speakers won't work . ???
Which kind of PL cable do you use?
You MUST use a fully wired cable - otherweise the amp won't turn on.
