problem connection beolab 14 sat with BV 10-32 ...
R911
Posts 7
R911 Posted: Sun, Jul 3 2016 5:04 PM
Hello,
I have a bV10-32 and I want connection my 2 beolab 14 sattelite with powerlink .....===>.
I connect a powerlinkcable between the BV 10 and the ampli. Type 1741 and I connect the speakers with the passive cable with the PLP2 ampli.  The speakers won't work . ???
Millemissen
Flensborg, Denmark
Posts 14,680
Which kind of PL cable do you use?
You MUST use a fully wired cable - otherweise the amp won't turn on.
Page 1 of 1 (2 items) | RSS
