I have connected an iPad cable to Tape 2 - all a working fine, when suddenly my MCP 6500 said there was 'No connect' and I couldn't turn off the iPad music.
Secondly, speakers crackled, made some din, as the volume was up, but couldn't turn it down.
I moved the MCP 6500 nearer to the 4 components and hey presto it connected and I was able to use it.
Has anyone else experienced this or is their a maximum distance the MCP should be from the component parts?
New batteries have been installed.
I recently had some things services and I asked about the same IR issue with my 6500. I was told that it is quite common for the BM6500 and a routine service should fix it. He quoted me about 120 £
The noise from the speakers sounds to me like a different problem.
