BeoVision Avant 28 DVD (type 8340).
Ahrend
Posts 6
Ahrend Posted: Tue, Jul 26 2016 6:14 PM
Can someone please tell me how I am supposed to command / instruct - with my beo4 - my DVD unit on top of my BeoVision Avant 28 DVD (type 8340).
Tnx,
Ahrend
[https://www.beoworld.org/prod_details.asp?pid=572:800:0]
Large photo
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Tue, Jul 26 2016 6:44 PM
If it's the same as the Avant 32 you use the buttons on the rear of the top right TV raised display to load/ unload the DVDs. You then use your Beo4 to play the DVDs or follow the DVD screen options.
Graham.
Ahrend
Posts 6
Ahrend replied on Tue, Jul 26 2016 7:30 PM
Hai Graham,
Your advice was a direct hit (which btw magically coincided with entering the Pulp Fiction dvd for testing the DVD-unit as such  )
Problem solved
thanks a lot.
At a later stage I will try to add a full DVD-function on the beo4.
Ahrend
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Tue, Jul 26 2016 7:31 PM
Hi. Arhrend.
Are you referring to the "missing " or at least very elusive "eject" command ?
Ahrend
Posts 6
Ahrend replied on Tue, Jul 26 2016 7:39 PM
Yes I did indeed, but as you might conclude from the answer given by Graham, the problem has already been completely solved
Thanks for your reaction.
Page 1 of 1 (5 items) | RSS
