Can someone please tell me how I am supposed to command / instruct - with my beo4 - my DVD unit on top of my BeoVision Avant 28 DVD (type 8340).
Tnx,
Ahrend
[https://www.beoworld.org/prod_details.asp?pid=572:800:0]
If it's the same as the Avant 32 you use the buttons on the rear of the top right TV raised display to load/ unload the DVDs. You then use your Beo4 to play the DVDs or follow the DVD screen options.
Graham.
Hai Graham,
Your advice was a direct hit (which btw magically coincided with entering the Pulp Fiction dvd for testing the DVD-unit as such )
Problem solved
thanks a lot.
At a later stage I will try to add a full DVD-function on the beo4.
Hi. Arhrend.
Are you referring to the "missing " or at least very elusive "eject" command ?
Yes I did indeed, but as you might conclude from the answer given by Graham, the problem has already been completely solved
Thanks for your reaction.
