Does 5500 Master Control operate Beogram 5500?
This post has 9 Replies | 0 Followers
TortugaX5
Columbus, Ohio
Posts 27
TortugaX5 Posted: Tue, Aug 2 2016 11:06 PM
I have recently purchased and setup a beogram 5500, which the great folks here helped me with on another thread.
My question is this, aren't I suppose to be able to control the turntable functions like turn and play from my master control and beolink 1000? It's not working...or I may be misinformed, which is likely.
Your help is appreciated!
Beosystem 5500 | Beomaster 5500 | Becord 5500 | Beogram 5500 | Beogram CD 5500 | Klipsch  RB-81 | Audioengine B1 Bluetooth DAC
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Tue, Aug 2 2016 11:11 PM
Make sure that the Beogram has got all of its 7 pins in the DIN plug. 2 of them are removable and these are the ones that control datalink.
TortugaX5
Columbus, Ohio
Posts 27
TortugaX5 replied on Tue, Aug 2 2016 11:26 PM
Can these pins be purchased? I will check to see but if they aren't in the cable, does someone on the forum sell them?
Lee
Posts 734
Lee replied on Tue, Aug 2 2016 11:41 PM
I don't think anyone sells them per se. But I'm sure someone will have a solution. IIRC you can get away with only having one. So you could remove the other pin from the Beogram CD and use it in the Beogram. I'm not sure which pin it is that can be removed so you'll have to do some testing.
Lee
Posts 734
Lee replied on Tue, Aug 2 2016 11:47 PM
I've just looked it up. Remove pin 6 from the Beogram CD lead (it unscrews) and install it into the pin 6 hole on the Beogram DIN plug. That should get them both working.
Lee
Posts 734
Lee replied on Tue, Aug 2 2016 11:51 PM
Looking at the DIN plug face on with the notch at the top, the top right pin is PIN 6.
TortugaX5
Columbus, Ohio
Posts 27
TortugaX5 replied on Wed, Aug 3 2016 12:09 AM
Could I instead sacrifice the pin from my beocord tape player?
Lee
Posts 734
Lee replied on Wed, Aug 3 2016 12:18 AM
Yes I don't see why not.
TortugaX5
Columbus, Ohio
Posts 27
TortugaX5 replied on Tue, Aug 16 2016 1:55 AM
Thank you, Lee! That was exactly the problem. The previous owners had broken the 6th pin off and it was barley above the surface of the threads for me to remove it with a pair of jewler tweezers. I replaced it with my beocord cassette salvaged pin and it's working like a charm now.
Ps. I was able to get an extension din cable made by Steve from sounds heavenly and that worked with the master control, too.
Lee
Posts 734
Lee replied on Tue, Aug 16 2016 11:32 AM
Fantastic :-) glad it's all working again as it should.
Page 1 of 1 (10 items) | RSS
