I have recently purchased and setup a beogram 5500, which the great folks here helped me with on another thread.
My question is this, aren't I suppose to be able to control the turntable functions like turn and play from my master control and beolink 1000? It's not working...or I may be misinformed, which is likely.
Your help is appreciated!
Beosystem 5500 | Beomaster 5500 | Becord 5500 | Beogram 5500 | Beogram CD 5500 | Klipsch RB-81 | Audioengine B1 Bluetooth DAC
Can these pins be purchased? I will check to see but if they aren't in the cable, does someone on the forum sell them?
Could I instead sacrifice the pin from my beocord tape player?
Thank you, Lee! That was exactly the problem. The previous owners had broken the 6th pin off and it was barley above the surface of the threads for me to remove it with a pair of jewler tweezers. I replaced it with my beocord cassette salvaged pin and it's working like a charm now.
Ps. I was able to get an extension din cable made by Steve from sounds heavenly and that worked with the master control, too.
