best remote for bs9000 mk1
This post has 3 Replies | 0 Followers
nethawk
Posts 20
nethawk Posted: Sat, Aug 27 2016 9:48 AM
I'm looking to buy a remote for my BS9000 MK1.
What options do I have? Beo 4? Anything else?
Wich version of Beo 4 will fit better the options in my BS9000? Any MK will work?
I want one remote that enables me to put AUX in the BS9000 in the more straight forward way.
Many thanks for your help.
leosgonewild
Helsinki, Finland
Posts 2,373
Any will do. A.tape activates a.aux
TWG
Posts 1,672
TWG replied on Sat, Aug 27 2016 11:40 AM
You can use a Beo 5, too and configure it nicely with e.g. 6 big CD icons for every single CD etc.
nethawk
Posts 20
nethawk replied on Sat, Aug 27 2016 4:24 PM
Thanks to both of you!
How easy is to select AUX in the BEO5?
BEO6 will work with a BS9000 MK1?
Page 1 of 1 (4 items) | RSS
