I'm looking to buy a remote for my BS9000 MK1.
What options do I have? Beo 4? Anything else?
Wich version of Beo 4 will fit better the options in my BS9000? Any MK will work?
I want one remote that enables me to put AUX in the BS9000 in the more straight forward way.
Many thanks for your help.
You can use a Beo 5, too and configure it nicely with e.g. 6 big CD icons for every single CD etc.
Thanks to both of you!
How easy is to select AUX in the BEO5?
BEO6 will work with a BS9000 MK1?
