Any advice on the best configuration (speaker roles) for a speaker grouping involving an Avant 55, two Beolab 18s and a Boelab 19? The 18s are positioned to either side of the TV, with the sub opposite and to the right, adjacent to a sofa and in a corner position. And any advice on how the speaker roles might vary between a general TV role and listening to music (using an Apple streaming service via the TV).
Thanks,
Andrew
Boodaboy:Any advice on the best configuration (speaker roles) for a speaker grouping involving an Avant 55, two Beolab 18s and a Boelab 19? The 18s are positioned to either side of the TV, with the sub opposite and to the right, adjacent to a sofa and in a corner position. And any advice on how the speaker roles might vary between a general TV role and listening to music (using an Apple streaming service via the TV). Thanks, Andrew
Great - thanks very much. Works well!
Any thoughts on how to hook up a turntable to the 18s and the 19, either via the TV or independently?
Cheers,
'Hook up a turntable':
You can use the multi-AV input onnection of the Avant.
Have a look at the Steve at Sounds Heavenly webpage - I am sure you will find the right adapter cable there.
the 18s have an input, so i think you can try to hook it up directly
Or if you had an essence you could use that and Wisa to the speakers - if you dont have the essence, well try the Avant
I would prefer using the tv, since you can 'tweek' the sound to your likings, make Speaker Groups etc for the turntable exclusively that way.
Millemissen:I would prefer using the tv, since you can 'tweek' the sound to your likings, make Speaker Groups etc for the turntable exclusively that way. MM There is a tv - and there is a BV.
Thanks, both - I'll try to hook up the turntable to the Avant in the first instance.
