Avant 55 - 18 -19 speaker configuration
Boodaboy
Posts 5
Boodaboy Posted: Mon, Sep 5 2016 9:16 AM
Any advice on the best configuration (speaker roles) for a speaker grouping involving an Avant 55, two Beolab 18s and a Boelab 19? The 18s are positioned to either side of the TV, with the sub opposite and to the right, adjacent to a sofa and in a corner position. And any advice on how the speaker roles might vary between a general TV role and listening to music (using an Apple streaming service via the TV).
Thanks,
Andrew
Aussie Michael
Melbourne, AU
Posts 3,730
Boodaboy:
Thanks,
Andrew
This is the exact combination that I have.
Because of the shape of my room I have:
> The avant at the front
> The 19 at the base of the avant
> The 18s as rears
I have a few speaker groups
TV > All avant speakers set to Centre
TV > Avant Left and Right (front) and Centre, 19 Sub
Movie > Avant Left and Right (front) and Centre, and the 18s as Left and Right rear and 19 Sub, I have put the DB up 2 on all
If you set the speaker distances remember it's the distance from where you sit.
Good luck with the setup
Boodaboy
Posts 5
Great - thanks very much. Works well!
Any thoughts on how to hook up a turntable to the 18s and the 19, either via the TV or independently?
Cheers,
Andrew
Boodaboy
Posts 5
Cheers,
Andrew
Millemissen
Flensborg, Denmark
Posts 14,680
'Hook up a turntable':
You can use the multi-AV input onnection of the Avant.
Have a look at the Steve at Sounds Heavenly webpage - I am sure you will find the right adapter cable there.
Aussie Michael
Melbourne, AU
Posts 3,730
the 18s have an input, so i think you can try to hook it up directly
Or if you had an essence you could use that and Wisa to the speakers - if you dont have the essence, well try the Avant
Millemissen
Flensborg, Denmark
Posts 14,680
I would prefer using the tv, since you can 'tweek' the sound to your likings, make Speaker Groups etc for the turntable exclusively that way.
Aussie Michael
Melbourne, AU
Posts 3,730
Millemissen:
Ah yes I forgot about that
Boodaboy
Posts 5
Thanks, both - I'll try to hook up the turntable to the Avant in the first instance.
Andrew
Page 1 of 1 (9 items) | RSS
