Two STBs on Avant 32
This post has 7 Replies | 2 Followers
Stones
Posts 59
Stones Posted: Wed, Feb 1 2017 3:56 PM
Hi
I would like to control two set top boxes on my Avant 32 RF DVD. It is possible via SAT and V.AUX. But on my Beo4 V.AUX can only be reached via LIST. That's a pitty when TV and V.TAPE buttons are unused. Is there a possibility to control to STBs directly via the primary source buttons?
S
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Feb 1 2017 4:35 PM
I had exactly this problem when I had a BV3 and 2 STBs.  Luckily I managed to find one of these:
Stones
Posts 59
Stones replied on Sat, Feb 4 2017 8:05 AM
Nice. What sources do the DTV, V.AUX and V.MEM open?
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Feb 4 2017 10:28 AM
Stones:
The same sources that they would control on a normal Beo4.
The advantage is simply that the TV button (which people often do not use) is replaced by V.AUX which is normally accessed via list.
On my BV3 setup, the DTV and V.AUX operated two STBs (one for UK Freesat TV, the other for Danish TV) and V.MEM controlled my V8000 video player.
Stones
Posts 59
Stones replied on Sun, Feb 5 2017 10:16 PM
If DTV=SAT and V.MEM=V.TAPE this one will do. Lucky for me that I found it in my kitchenStick out tongue
Beobuddy
Utrecht, The Netherlands
Posts 3,972
With this Beo4 you still need the V-AUX instruction beneath the LIST button.
As you already mentioned you have the 2 instructions STB(DTV) and STB(V-AUX) to control both settopboxes.
Depending on the softwareversion STB(DTV) can also be STB(SAT).
A.Mem is the same as ATAPE and V.MEM is V.TAPE.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Feb 6 2017 9:46 AM
Another thought:  If you have a BeoLink 1000 (the older remote without the screen) then you can get V.AUX by pressing SHIFT then TV.
Personally I would just accept using the LIST button.  With your newer Beo4 you should be able to move V.AUX within the stored list, so that it appears first when pressing LIST.
Stones
Posts 59
Stones replied on Tue, Feb 7 2017 7:42 AM
You're right. Maybe I would have to look at my Beo5
Page 1 of 1 (8 items) | RSS
