Connect one pair of beolab 3 to both beosound 3200 and beosound 5 at same time
This post has 11 Replies | 1 Follower
Peiya
Posts 8
Peiya Posted: Sun, Oct 2 2016 1:30 AM
Hi I have a beosound 5 encore and a beosound 3200
what device should I get to connect the two system to one pair of beolab 3 with only one on at a time?
I guess a 1 female 8 pin to 2 male 8 pin cable ?
will this harm any device if I only open one ( 5 or 3200) at same time?
Peiya
Posts 8
Peiya replied on Sun, Oct 2 2016 3:54 PM
Any one knows whether I can achieve this without using the almando switch which is so expensive?
thanks
leosgonewild
Helsinki, Finland
Posts 2,373
Can you connect the Encore to the aux in on the BS?
Peiya
Posts 8
Peiya replied on Sun, Oct 2 2016 9:27 PM
I think only another cable I can make it
but I never use Aux before
what  will happen if I do so?
Thank you a lot for replying
Millemissen
Flensborg, Denmark
Posts 14,680
You can use the Aux connection.
But you will have to deal eith two volume controls.
Since the Aux-in of BS3200 will expect a signal at line-level volume, you will have to turn the Encore up to a fitting volume.
Best do all volume control afterwards with the 3200/the Beo4 on the 3200.
Tip: best set the Encore to Option 0 or Option 4 - so that it won't react directly to the commands of the Beo4.
The Almondo is merely a switch.
But it is an intelligent one - and imo worth the price, if you really need and use it.
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Oct 2 2016 10:32 PM
Look for Almando Powerlink Switch. Get some knowledge about link options as well. Too tired to think about details...
Best regards
Ralf
Peiya
Posts 8
Peiya replied on Sun, Oct 2 2016 11:12 PM
So if encore is connected as AUX
if can be viewed as a outerner music source for the beosound?
The music is stored in the encore and played by beosound, right?
thank you for answering!
Peiya
Posts 8
Peiya replied on Sun, Oct 2 2016 11:14 PM
I m sorry I'm kinda confused
In this case how can I play musics stored in the encore?
Peiya
Posts 8
Peiya replied on Mon, Oct 3 2016 7:49 PM
Hi guys what if I want a third part? A beoplay Maker?
any possibility?
thanks
Peiya
Posts 8
any possibility?
thanks
Peiya
Posts 8
any possibility?
thanks
TWG
Posts 1,672
TWG replied on Tue, Oct 4 2016 6:52 AM
Peiya:
- Yes
- Yes
- You're welcome Wink
Page 1 of 1 (12 items) | RSS
