Hi I have a beosound 5 encore and a beosound 3200
what device should I get to connect the two system to one pair of beolab 3 with only one on at a time?I guess a 1 female 8 pin to 2 male 8 pin cable ?
will this harm any device if I only open one ( 5 or 3200) at same time?Thanks
Any one knows whether I can achieve this without using the almando switch which is so expensive?
thanks
I think only another cable I can make it
but I never use Aux before
what will happen if I do so?
Thank you a lot for replying
You can use the Aux connection.
But you will have to deal eith two volume controls.
Since the Aux-in of BS3200 will expect a signal at line-level volume, you will have to turn the Encore up to a fitting volume.
Best do all volume control afterwards with the 3200/the Beo4 on the 3200.
Tip: best set the Encore to Option 0 or Option 4 - so that it won't react directly to the commands of the Beo4.
The Almondo is merely a switch.
But it is an intelligent one - and imo worth the price, if you really need and use it.
So if encore is connected as AUX
if can be viewed as a outerner music source for the beosound?
The music is stored in the encore and played by beosound, right?
thank you for answering!
I m sorry I'm kinda confused
In this case how can I play musics stored in the encore?
Hi guys what if I want a third part? A beoplay Maker?
any possibility?
Peiya: So if encore is connected as AUX if can be viewed as a outerner music source for the beosound? The music is stored in the encore and played by beosound, right? thank you for answering!
