How to remove and refresh white side trims on a Beogram 2200?
Hiort
Sweden
Posts 2,895
Hiort Posted: Fri, Oct 7 2016 2:28 PM
Have a Beogram 2200 that was the very first Bang & Olufsen equipment I purchased.
I purchased it new in the late 70:s.
I now intend to bring it down from the attic and give it some love.
Questions:
How do I snap loose the white trims around the body. Is it just to snap loose? Can´t tell from the service manual on Beoworld.
Any idea on how to make the white pieces white again. They have turned yellow. I guess paint would work?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Oct 7 2016 2:49 PM
Take off the Beogram bottom plate.
Then you can slide the panels away from the chassis.
Don't just pull them!
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Oct 7 2016 2:53 PM
Perfect!
Thanks!
Will post pictures.
Page 1 of 1 (3 items) | RSS
