Have a Beogram 2200 that was the very first Bang & Olufsen equipment I purchased.
I purchased it new in the late 70:s.
I now intend to bring it down from the attic and give it some love.
Questions:
How do I snap loose the white trims around the body. Is it just to snap loose? Can´t tell from the service manual on Beoworld.
Any idea on how to make the white pieces white again. They have turned yellow. I guess paint would work?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Take off the Beogram bottom plate.Then you can slide the panels away from the chassis.Don't just pull them!
Perfect!
Thanks!
Will post pictures.
