After trying to setup this BM with a BL3500 MK2 - with no success - I now experince this strange behaivor:The main loudspeaker output is ok, but the 2.nd ones is lacking bass. I switch the 2 pair of speakers but it remains the same situation.Are there any service code / options I could have setup by mistake?
Any help / advice are appreciated.
Leif: After trying to setup this BM with a BL3500 MK2 - with no success - I now experince this strange behaivor:The main loudspeaker output is ok, but the 2.nd ones is lacking bass. I switch the 2 pair of speakers but it remains the same situation.Are there any service code / options I could have setup by mistake? Any help / advice are appreciated.
There is no difference internally between speaker 1 and 2 on the Beomaster 6500, only difference is that speaker 1 goes through a mute relay.
So if there should be any difference, it should be the speaker 1 that would go bad because of physical problems with the relay.
Are you sure you got 1 and 2 right ? Speaker 1 is the ones closest to the cooling ribs.
/Jacob
Hi Leif,
How did you connect the Beolab 3500 mk.2 to the Beomaster 6500 please? Is this with a direct Powerlink cable, or from the 3/4 pin Speaker outlets via an ML/MCL Converter? We can then help you to get everything working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
