Beomaster 6500 loudspeaker mis-behaving
This post has 2 Replies | 2 Followers
Leif
Middle Jutland in DK
Posts 130
Leif Posted: Fri, Dec 8 2017 6:44 AM
After trying to setup this BM with a BL3500 MK2 - with no success - I now experince this strange behaivor:
The main loudspeaker output is ok, but the 2.nd ones is lacking bass.
I switch the 2 pair of speakers but it remains the same situation.
Are there any service code / options I could have setup by mistake?
Any help / advice are appreciated.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Dec 8 2017 7:19 AM
Leif:
There is no difference internally between speaker 1 and 2 on the Beomaster 6500, only difference is that speaker 1 goes through a mute relay.
So if there should be any difference, it should be the speaker 1 that would go bad because of physical problems with the relay.
Are you sure you got 1 and 2 right ? Speaker 1 is the ones closest to the cooling ribs.
/Jacob
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Leif,
How did you connect the Beolab 3500 mk.2 to the Beomaster 6500 please?  Is this with a direct Powerlink cable, or from the 3/4 pin Speaker outlets via an ML/MCL Converter?  We can then help you to get everything working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
