changed the bulbs on a beomaster 900 but still no lights???
Loadoner
Posts 6
Loadoner Posted: Fri, Nov 11 2016 1:39 PM
I changed the nice looking Philips 6,3 V 300mA bulbs, with new ones.. (7V 300 mA and they look not that well made as the originals)
left and right, but no light....:(   I did read that the 7V are lasting longer.. thats why I bought the 7V....
If someone could advise me what I could do!! Winter is coming and some working lights would be really needed!:)
Søren Mexico
Mexico City
Posts 6,411
Is the 900 working ?, if yes check the power feed to the lamps, check inside of the sockets first and then according to diagram backwards until you find out where it disappears, maybe it is only corrosion inside the sockets
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Nov 11 2016 8:04 PM
The dial light bulbs have their own fuse (located far apart from the other fuses) and for some reason that fuse socket tends to corrode. I'll bet that you will find green growth in it. Clean it carefully, it will probably be fragile as well.
--mika
Page 1 of 1 (3 items) | RSS
