Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
DMacri:I know the MCL 2, xtra, AV, and so on will not work on older MCL systems like the BS5000, but can the MCL82 relay boxes work, even in a limited fashion, on the newer BS6500? If so, what are the limitations? Dom BeoSystem 5000, BeoSystem 6500, AV 7000, BeoSound 4000, Playmaker, BeoLab 2500, BeoVox S-45, BeoVox S-45.2, RL-140, CX-50, C-75, CX-100, 3 MCL82 link rooms, A8 earphones, A3, 4001 relay, H3, H6, and ambio
The following table may help you.
Which MCL can be used for which product?
MCL 2AX-tra speaker kit
MCL 2AVX-tra active speaker kit
MCL 30
MCL 82
Beomaster 3300
*1
Beomaster 4500
Beomaster 5500
Beomaster 6500
Beomaster 7000
Beocenter 8000
Beocenter 8500
Beocenter 9000
Beocenter 9300/9500
Beomaster 3000
Beomaster 5000
Beomaster 6000
*2
Beomaster 8000
*3
Beocenter 7000
Beocenter 7002
Beocenter 7007
Beocenter 7700
*1 Beomaster 3300 does not feed an answer back to the MCL which means that the stand-by indicator does not work. Furthermore the loudspeaker relay is not disconnected at stand-by, which means that when the audio system is activated again, it will start playing in the very rooms where it was turned off. The loudspeakers in the central room will always be cut in.*2 In addition to the number of MCL 30 units necessary for the installation one MCl Beolab kit type 1006/1007 is required.*3 All MCL 82 units must be modified and an MCL Beolab kit type 1006/1007 is required for each installation.
Regards Keith....
