I just ordered a BeoSound Essence MkII. I'm trying to understand which sources will streaming to multiroom. Is AirPlay the only sound that will not go over multiroom? Can I bluetooth to my essence and join my A9 gen 2 by tapping it or do I need to use one of the streaming sources on the essence?
Any clarification would be great! Thanks.
Austin:I just ordered a BeoSound Essence MkII. I'm trying to understand which sources will streaming to multiroom. Is AirPlay the only sound that will not go over multiroom? Can I bluetooth to my essence and join my A9 gen 2 by tapping it or do I need to use one of the streaming sources on the essence? Any clarification would be great! Thanks.
These are great options! I will most likely stream bluetooth then spread that to the other B&O multiroom products.
For iTunes NAS, do I use Twonky from B&O's website on my mac?
think people who use NAS drives use a variety of media servers (Plex, Kodi, Twonly etc).....there's been a few threads previously on this.....
https://www.flatpanelshd.com/downloads/BeoLinkMultiroomWhitePaper.pdf
the link above may be useful, a white paper on multi room setups and limitations i think.....and yes Airplay comes with Apple restrictions, though if you Airplay music to an Apple TV it then works fine......(its what i do a lot, as my BV12 is generally on a lot)......the BS treats it as a video source, so the restriction doesnt seem to apply......
mjmedlo:I do think any product with Spotify connect can join the Spotify feed.. but I don't think you can BeoLink multi room Spotify connect
That's correct, the limitation is that it will work with other multiroom products that also support spotify connect, but not with those that do not.
Martin.
