Multiroom Streaming
This post has 9 Replies | 2 Followers
Austin
United States
Posts 136
Austin Posted: Mon, Jan 9 2017 3:09 PM
I just ordered a BeoSound Essence MkII. I'm trying to understand which sources will streaming to multiroom. Is AirPlay the only sound that will not go over multiroom? Can I bluetooth to my essence and join my A9 gen 2 by tapping it or do I need to use one of the streaming sources on the essence?
Any clarification would be great! Thanks.
mjmedlo
Posts 922
mjmedlo replied on Mon, Jan 9 2017 5:08 PM
Austin:
Correct
AirPlay is limited , but Spotify is another that will not stream over BeoLink.
The Bluetooth connection WILL stream to multiroom
Steve_torque
Dorset, UK
Posts 145
You can stream Spotify connect to B&O multi room, as long as you are premium account holder.
I am now, with my essence 2 and a6. A few people on here seem to think this isn't possible. But it is, which is good Smile
So just AirPlay, unless you have an Apple TV connected...I think I have read. Not tried it though as mainly use line in for tv (non beo), tunein, Spotify and dlna for my NAS.
Any other questions please ask
Austin
United States
Posts 136
Austin replied on Mon, Jan 9 2017 7:21 PM
These are great options! I will most likely stream bluetooth then spread that to the other B&O multiroom products.
For iTunes NAS, do I use Twonky from B&O's website on my mac?
Sandyb
Posts 2,186
Sandyb replied on Mon, Jan 9 2017 7:35 PM
think people who use NAS drives use a variety of media servers (Plex, Kodi, Twonly etc).....there's been a few threads previously on this.....
https://www.flatpanelshd.com/downloads/BeoLinkMultiroomWhitePaper.pdf
the link above may be useful, a white paper on multi room setups and limitations i think.....and yes Airplay comes with Apple restrictions, though if you Airplay music to an Apple TV it then works fine......(its what i do a lot, as my BV12 is generally on a lot)......the BS treats it as a video source, so the restriction doesnt seem to apply......
Steve_torque
Dorset, UK
Posts 145
Agree with sandyb, you can use a variety. I used Plex fine with my iMac and iTunes. Up to you if you want to pay for Twonky. I use a dedicated NAS now, and just use the built in media server on that with no problems.
mjmedlo
Posts 922
mjmedlo replied on Mon, Jan 9 2017 11:33 PM
I sortof agree with you SteveGee.
I do think any product with Spotify connect can join the Spotify feed.. but I don't think you can BeoLink multi room Spotify connect.
At least I can't.. I can only make it link to other Beoplay products.. but not to my beosystem4 or my converter
Steve_torque
Dorset, UK
Posts 145
mjmedlo - Ah I see. I was only talking about the new products - as that's all I have and as the essence 2 and A9 were mentioned in the first post.
Good to know though, thanks
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Jan 10 2017 12:08 AM
mjmedlo:
That's correct, the limitation is that it will work with other multiroom products that also support spotify connect, but not with those that do not.
Martin.
steve1977
Posts 911
steve1977 replied on Tue, Jan 10 2017 12:25 AM
there is a rather easy work-around for airplay/spotify to go multi-room. just use the line-in. i have an airport express at one line-in and a chromecast audio at another line-in.
flawless multi-room with b&o nl :)
Page 1 of 1 (10 items) | RSS
