Beo Remote One
This post has 5 Replies | 2 Followers
991fan
Posts 33
991fan Posted: Sat, Oct 4 2014 12:25 PM
Hi All,
I've just had an Avant 55 installed, very happy with it.
Does anyone know which button to use on the remote to record on sky though? it's the only thing I can't figure out.
Paul
malcolm welborn
canary islands
Posts 188
I have sky  on my beo4 press menu then 8  an r will then be against the programme you are going to record
cheers
malcolm
beoair
Posts 13
beoair replied on Sat, Jan 21 2017 2:49 PM
Hi Paul
I'm just having the same problem with my Beoremote 1 and Sky+HD on my BV14-55. Did you ever get an answer from anyone. Thanks
Millemissen
Flensborg, Denmark
Posts 14,680
There should be an overlay menu (from the PUC), when you press Menu - this should show you which button/button combination to use.
beoair
Posts 13
beoair replied on Sat, Jan 21 2017 3:31 PM
Hi Everyone. thanks for your answers but I've just worked it out. With the future program you want to record highlighted in the sky guide, press the list button on the Beoremote 1, highlight Sky HD as the source, there is a "right arrow" next to it. Press the right arrow on the main selector and then scroll down to the "record" label. Select that and the usual "record once, record series" window appears. Use the up & down arrows to select then go.
Best Wishes
Aussie Michael
Melbourne, AU
Posts 3,730
Or you can do menu 8 I think
Page 1 of 1 (6 items) | RSS
